3.1L to 3.1L (From Lumina to Firebird, work?)
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I was wondering, after I came up empty handed on a search, if a 3.1L V6 from a Lumina, FWD, would fit into my 92 Firebird with a 3.1L. Reason I ask is because I plan on rebuilding the 3.1L from the lumina, and dropping it into my firebird.
I need to know if its a direct bolt in, and if not, what wont fit.
Thanks alot.
Thanks alot.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
The FWD and RWD 3.1 engines are not swapable if I remember correctly. FWD and RWD is cast on the blocks for that reason.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
are they swappable? well, got a welder?
search in the v6 forum and you'll find the answers you're looking for.
colton_carlson
Mar 8, 2019 12:21 PM
