Where to connect clutch switch plug?
Apologies in advance if this is the wrong forum...
I'm in the final stretch of my swap (305 to 355) and I ran into a problem with the wire harness branch that goes back to the trans (T-5). I know that the plug with the green and blue wires goes to back-up light switch (LH side of tranny case) , but what does the one on the end plug into? I'm pretty sure it's the clutch switch (purple and yellow wires) but I see nothing within reach.
Anybody know?
TIA,
Bob
Anybody know?
TIA,
Bob
Yes. Disables starter when clutch pedal isn't down.
At least that's what I think it is.
The harness branch breaks out on the left hand side of the large one that runs across the back of the engine. The Back-up light plug is located halfway down the branch; the plug in question is at the very end.
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
The clutch safety switch is typically on the clutch pedal on most manual transmission cars, nto to sure on thirdgens. Worse comes to worse just by-pass the switch and hook the two wires together.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
