'90 305TBI to '86 305TPI
Car: '90 RS (beater) / '87 IROC (project)
Engine: L03 305 / L98 350
Transmission: 700-R4 / 700-R4
The 305tbi in my beater is very tired (208k miles), and I have a 305tpi out of my deceased '86 IROC that I'd like to put to good use. I stripped the '86 clean, so I should have everything I need from the donor car. I've been told that the difference in years would make this swap a major pain. I assume it has to do with the VATS. Could someone clarify this? Also, the '86 engine and tranny have been sitting in the garage for 5 years. Both ran like a dream before the accident. What all would I need to do to freshen them up before the swap? Any and all info is greatly appreciated.
Transmission: 4L80E/4L80E
If the engine was properly closed when removed, then fresh fluids and things like plugs is all it will need. Probably wouldn't hurt to remove the plugs and squirt a little oil in each cylinder and turn the engine over several times.
I don't know enough about the specifics of '90-up to speculate about what problems you'll encounter.
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
