305 TPI swap to LS1/700R4 and 10-bolt 3.73
Old Jul 26, 2005 | 11:45 PM
99 outlaw's Avatar
Car: 2006 Silverado
Engine: 5300 Vortech v8
Transmission: 4L60E A4
Ok, I am looking into purchasing a 1989-1992 IROC Z that is completely stock. I want to do an LS1 swap with a 700R-4 transmission and a 3.73 10-bolt rearend. How hard would this swap be and what all do I need to change to make it fit?
Old Jul 27, 2005 | 09:49 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The swap isn't bad, the stickies at the top of the page can get you in the right direction, you will have to swap motor mounts, notch the k-member (if you keep air) and do the wiring to hook up the gauges.
Don't use a 700R4 with the LS1, do a 4L60E since it is all computer controlled and you can adjust shift points, line pressure etc etc in the tranny, plus I don't think anyone makes a TB bracket that has the provisions for a TV cable.
Old Jul 27, 2005 | 09:55 AM
99 outlaw's Avatar
Car: 2006 Silverado
Ok, after extensive reading on here it looks like it'll be easier to do a carb 350 swap. Main thing I'm seeeing is the clearance in the motor. Is this true?
Old Jul 27, 2005 | 03:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, it's not true.
Old Jul 27, 2005 | 04:08 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
If you want to do that swap get a 4L60E or a T-56. I would choose the T-56 bro.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
