pulling a 305 out...
Old Jul 27, 2005 | 08:29 PM
Metaldrgn's Avatar
Car: Yukon, Tahoe, Expedition, JGC
How can I get the crank to not turn while I try and losen the 3 bolts that connect it to the torque converter? Yes it's an automatic and a 350 is going in place of it and I need to know before tomorrow because I don't have another car and I have to work the day after tomorrow. Can I remove the engine with it attacked or is that a bad idea?
Old Jul 27, 2005 | 09:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
we used a big 'ol flathead screwdriver to hold teh flexplate still when breaking the bolts loose.
Old Jul 27, 2005 | 09:35 PM
Metaldrgn's Avatar
thanks for the input, I didn't even think of that!
Old Jul 28, 2005 | 09:06 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I removed the oil filter, then put the head of the ratchet right up agianst the bellhousing, then turn. It was simple and I didn't have to fiddle around.
Old Jul 28, 2005 | 09:22 PM
Metaldrgn's Avatar
the rings are wearing bad so it doesn't take much to turn it. The screwdriver trick worked. That was actually the easiest part of the day. getting those 6 bolts out of the bell housing were a pain the the A#*. One got stripped out and I spent a good hour getting that out. Oh I got to the bolts by tilting the tranny down. I was getting in a hurry tonight and almost lowered the new engine in without the mounts. I left the old shock absorbers on to save time (where the mounts rest on). My flowmaster exhaust is breaking in the back before the muffler so some day soon I will have to weld that back together.
I thought I would've been done today, but it looks like I will have to work on it tomorrow and still leave it there till my next day off. If I would've known it was this hard I would've made sure I had another car for transportation. I do have another car, but I've gotta go to court first and get the title back that way (long story). It's not running either, but I am part to blame for that because I was porting the heads and broke through one of hte exhaust chambers into the water jacket so I need to use the heads from this car to get the other one running and after I get the title back I can drive it. I hope after all this I don't spin a bearing or something. I would be screwed to say the least all because I wanted to hurry up and build/install this engine.
Old Jul 28, 2005 | 10:10 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Those bellhousing bolts are easy as cake with a 3 ft extension, tranny tilted down, and a universal right by the socket. Honestly took me 30 min to get em all.
Old Jul 29, 2005 | 08:58 AM
Metaldrgn's Avatar
yea today I've got a few hours before work so I can put some of those critical bolts in and roll it off of the lift.
Jake_92RS
Jan 28, 2020 10:37 PM
GouldyGTR
Aug 21, 2015 10:43 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
