V6 serpentine swap to 5.7 TPI?
Old Aug 4, 2005 | 12:20 PM
mrrilla's Avatar
Car: 1939 Chevy Coupe
Engine: 383 TPI, Dart Pro1 180cc heads, etc
Can anyone verify which sepentine brackets and accesories will transfer from a V6 motor (86-91) to a 5.7 TPI?
Old Aug 4, 2005 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
I haven't dealt with the V6 serp setup personally, but the quick answer to your question is probably "nothing". You may be able to use the AC compressor, PS pump, and alternator with V8 brakets and hoses/wiring.
Old Aug 5, 2005 | 02:48 PM
chesterfield's Avatar
Car: Pontiac
Your probably thinking of the 90 degree 4.3 v6 which some people describe as a small block chevy with two cylinders chopped off. (not used in f-bodies) As I recall from my visits to the wrecking yards the serpentine system looks very similar but I don't know if its a direct bolt on. If you're up for converting a non-serp and are willing to give it a try, don't forget to get a reverse rotation waterpump.
Old Aug 5, 2005 | 03:40 PM
five7kid's Avatar
mrrilla, I assumed you were talking about your current 3rd gen V6, into which you are planning on swapping a V8. Correct?
Old Aug 6, 2005 | 12:09 AM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
All serpantine components from a 4.3 WILL go on a smallblock,but you usually have to either run an unhooked smogpump,or fab up an idler pulley in it's place.
Old Aug 10, 2005 | 12:47 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I don't know if it will bolt up to a V8. The F-body V6 has the A/C comp. on the drivers side and the Alt. is on the pass. side. F-body V8 are totally opposite. Vette setups are different also,clearance issues.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
jharrison5
Aug 19, 2015 05:53 PM
jahblah
Aug 12, 2015 05:54 PM
Sanjay
Aug 12, 2015 03:41 PM
