Final re cap before swap
Old Aug 11, 2005 | 08:52 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
OK, So Im attempting the V6 - V8 swap....not just an oridinary v8, its a 400hp 435tq 383. I just wanna get this right.
So heres my list -
Engine - getting built
Headers - need
Cat back - need
Starter - need
Alternator - need
alternator bracket - getting from boneyard
Carb - need (holley 770sd)
Oil pan - need
Tranny Cross member- need
TH350 (shift kit) tranny - Got it
Rad - need
SFC's - on order
Torque arm - on order
Ok, so if Im thinking right this is all Im gonna need right?
What are your opinions on power steering? With my 6 right now the power steering belt went and Im not having any problems.... opinions?
Everything else is pretty much straight forward....take that old peice of **** out and put all the new stuff in
Let me know if i forgot anything
Old Aug 12, 2005 | 12:24 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
I just did a swap and you'll need lots of misc. hoses and stuff. I didn't see motor mounts or if you want a working tach you need a v-8 tach . New springs too but some people leave the v-6 ones in. I also needed to buy a few sensors like water temp and oil pressure.
As far as power steering my old v-6 pump looked the same but I went to serp set up so I just used the one that came with the v-8. Just unooked the hose from the old and put them in the new.
Old Aug 12, 2005 | 06:14 PM
Car: 1987 Z28
I was todl the v6 mounts will work just need to move them up??
and a v8 tach thanks for reminding me
I hope thats all, guess I can always just goto the junkyard and get the misc crap I may need
Old Aug 12, 2005 | 06:32 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
im almost done with this swap. im not sure what else in suspension. mine hasnt really dropped at all and it still has v6 springs, and i still have to drive it. but make friends with ACE because i have to get so many nuts and bolts. the swap isnt hard its just a little tedious. yes tedious....
Old Aug 12, 2005 | 11:04 PM
ejm's Avatar
ejm
Engine: Carbed 350
I don't have the old ones to measure or look at but I am pretty sure they were different. Also new rubber ones only cost 11 bucks at napa or you might want to get polyurthane.
1992 Trans Am
May 10, 2023 07:19 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
