305-350 tpi
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
305-350 tpi
Ok im just trying to get an idea of where im going to have problems. The car has a 305 700r4 and is an 86. It will have a 350 700r4 from an 89 swapped into it.
Wiring wise what has to be changed? I have the donor car will it be easier to swap the wiring harness or can i leave the 86 harness and mod it a little?
I know the 89 has no cold start injector... what other differences are there?
Transmission: 4L80E/4L80E
Is there any reason you aren't using the '86 TPI on the '89 engine? That would be the easiest route. No wiring changes, use the injectors & regulator from the '89, you should be good to go.
Otherwise, unhook the harness from the passenger kick panel pass-through and put on the '89 stuff using the '89 ECM & harness. It shouldn't be that hard.
Engine: 350 tpi
Yeah i was hoping i could go that route...
Unfortunately the seller whom i had been in contact with for 4 days sold the car to someone else... sonofabitch...
Sanjay
Aug 12, 2015 03:41 PM
