TPI to LT1
Old Aug 16, 2005 | 07:02 PM
19IROC87's Avatar
TPI to LT1
will LTI heads and intake bolt up to a 87 350 TPI motor and is the 350 block the same from 86-96
Old Aug 16, 2005 | 07:31 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
With some major modifications of the heads and intake so you kill the reverse cooling, yes.
The block is a bit different since the waterpump is driven off of the cam instead of a belt, they changed the upper part of the timing chain cover to make up for the gear to drive the waterpump.
The LT1 is considered a Generation II smallblock.
Best thing to do is go ahead and put the LT1 in the car.
Old Aug 28, 2005 | 09:11 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Almost right.
LT1 Heads and Intake will bolt to a 350, however, there is no hole for your Distributor. You have to modify the intake, and you have to make some plumping changes to correct for the reverse flow design of the heads.
http://www.lt1intake.com/ Has information you are looking for.
I have heads and intake for sale if you're looking btw.
Also, you aren't going to get that great of a bump by sticking the intake and heads on there.
Best bet would be to either swap the whole LT1 or do that head and intake package with a cam, and possibly lower end build.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Sanjay
Aug 12, 2015 03:41 PM
