V6 to V8 Question
Old Aug 28, 2005 | 05:02 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
V6 to V8 Question
Where do i start? where does the engine bolt to the chassis and where else is it bolted up?
Old Aug 28, 2005 | 05:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to get yourself a shop manual. Those questions are so basic, we don't really want to cover them in detail here. A Haynes or Helms manual will describe it in sufficient detail to get you through it. Be sure to take pictures of things before you start disassembling and while in the process, and label everything as you remove them.
It could be said that if you have to ask questions like that, then you're probably over your head with an engine swap. But, you have to start somewhere, so if you're willing to bone up with the shop manual, and be disciplined as you go through the process, you can get there.
Old Aug 28, 2005 | 09:13 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Yeah a shop manual would be best. Aslo at the top is a v-6 to v-8 sticky. Plus you have hundereds of people to help you on this board.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
