Response
Old Sep 2, 2005 | 08:55 AM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
Response
Torque definitely makes a difference in a street car. However, with the gas prices getting ridiculous, a smaller displacement 327 (in comparison to a 350) may not be that bad an idea. You should see an mpg or two from the smaller engine, and it'll tend to make more power than a 305. So I still see a 327 as an upgrade to a third gen.
Don't expect miracles though, the 3rd gen is a fairly heavy car for a little 327. I would suggest the smaller cam that improves torque response over a larger, lopier cam. However, if you'd rather have the lope, then at least improve your rear end gears. 3rd gens were also notorious for their tall rear end gears in most cases. With a 700R4's 3.06 first gear ratio, anything shorter than a 3.08 will give a good launch.
I've found the 3rd gen drivetrain to be fairly tough over the years. Provided you don't hammer it 100% of the time, with a warmed over 350, I have never had trouble with my 700R4 or rear end. So I don't think sticking a 327 in a 3rd gen will hurt such a drivetrain...however, a T5 might be tested by the 327's higher horsepower.
Old Sep 2, 2005 | 09:33 AM
Car: 1986 IROC-Z
Oops, hit the post button instead of reply to topic button.
Moderator, if you want to delete this, it's okay.
Kind of looks dyslexic to me...but if it works as a new thread, whatever...
Sorry.
86White_T/A305
Mar 6, 2016 01:48 PM
meeklay812
Oct 1, 2015 03:46 PM
BWilcox
Sep 20, 2015 12:19 PM
dementednut
Sep 10, 2015 09:50 PM
rsrookie
Sep 5, 2015 07:08 PM
