Help with piston choice
Old Sep 12, 2005 | 11:35 PM
CamaroSpeed's Avatar
Car: 1987 IROC
Engine: 305 Tpi
Transmission: 700r4 With B&M Rebuild Kit & 2800 S
I'm geting ready to buy part's for my rebuild. Here's the Q can I put dish top piston's in the 350 with L98 aluminum head's will that work the piston's are TRW P/N L2403F30 can anyone help with this
Old Sep 13, 2005 | 09:28 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Determine what compression ratio(cr) you want to run first. If you want to use any type of forced induction you want to have a lower cr.
Start by picking out the heads you want to use, if you haven't already. Then the head gaskets, rod length, and consider if you are going to bore the cylinders over any. Then add in your pistons and determing how much of a recess you need to gain the desired cr. That will tell you if the piston you pick out will work for your application.
gixxer92
May 18, 2017 11:20 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
