305 TPI to 350 Carb.
Old Oct 7, 2005 | 09:44 AM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
I'm planning on taking out my stock 305 in my 91 RS and putting in a 350 Carb. I don't know much about engine swaps I've only done it once, I was just wondering if you guys know any facts about this, wheather you think its going to be quite difficult or not? Thanks
Old Oct 7, 2005 | 03:53 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Not to difficult. Sorting out the wires in a pain, other than that. You will need to find a solution for the torque converter lockup (if you want to keep it) and what you want to do about a fuel pump. Use the existing in tank pump with a new regulator or go mechanical.
Old Oct 7, 2005 | 05:59 PM
Car: 1991 camaro RS
Yeah, I already got a new fuel pump and a new tank, ill post some pics of it when I get it done. I was thinking about getting the long pipe hooker headers but im thinking it'll hit on the bottom because its a little droped in the front. so I guess I gotta go with the short Y pipes.
Old Oct 7, 2005 | 10:07 PM
vrtc350's Avatar
Car: 81 Corvette
Most like the Hooker 2055's.
Also, you can keep your electric fans, just buy a new temp switch and wire it to your fan relay. Should do the trick.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
