corvette motor in camaro
Old Oct 10, 2005 | 06:25 PM
1986roczred's Avatar
Car: 1986 irocz
Engine: 305 carb
Transmission: 5 spd
alright i have a 86 iroc and theres this motor im looking at putting in IF POSSIBLE. what all would have to be done to put a 88 or 89 350 out of a corvette in my camaro which is 305??
Old Oct 10, 2005 | 07:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
You'll need to change the oil pan and pump pickup, and the knock sensor & module for a 350.
You're keeping your current carb set-up, correct?
Old Oct 10, 2005 | 08:38 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Very possible common swap esp. on these boards what 5.7 kid said is pretty much the gist of it if you keep the carb setup it is a pretty str8 forward project.
Use the button
Old Oct 10, 2005 | 08:52 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
I had the same setup in a formula mine was built it was a fun ride. it is a pretty straight foward project
Old Oct 11, 2005 | 10:16 AM
five7kid's Avatar
Forgot to mention the EGR valve won't work because the Vette aluminum heads don't have the exhaust cross-over passages the '86 carb system uses to feed the EGR valve the needed exhaust gases.
Old Oct 19, 2005 | 04:07 PM
Car: 1986 irocz
Engine: 305 carb
Transmission: 5 spd
carburator
i have the regular quadrajet carb thats been rebiult recently. it will go on the 350?
im also researchin trannys for it. but not too sure on what really should be lookin for. lookin for manual though
Old Oct 19, 2005 | 06:48 PM
five7kid's Avatar
The intake manifold and all the support equipment from your 305 will bolt onto the Vette engine and run it just fine.
What transmission is a whole 'nuther topic.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
kah992
Aug 19, 2015 02:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
