89 TA/Camaro
Old Nov 1, 2005 | 03:26 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
89 TA/Camaro
I seem to have finally found a perfectly priced and located engine for my 89 RS. The engine i am looking at came from an 89 trans am. Its a 350TPI and my camaro originally had a 305 TBI....Is this a compatible swap? Is there a lot of work involved? The thing is complete so i would have pretty much all parts. Thanks guys,
Steve
Old Nov 1, 2005 | 03:30 PM
TexasLT1's Avatar
Car: '92 RS
Steve, its definitely a worthwile swap, and one that has been accomplished many times before. You can search the board for all of the information you could possibly want on that swap. The physical swapping of the engines is a piece of cake, unbolt the 305, pull it out, drop in the 350, bolt it in. The wiring harness and fuel requirements are the only things that will take some work, and then its just a matter of making sure everything is connected correctly.
Old Nov 1, 2005 | 03:57 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
350 swap
thanks alot nic....i appreciate the help
steve
RiggsLW81
Nov 10, 2007 07:36 PM
ZQ8Dude
Jun 22, 2005 06:48 PM
RegaPlanet
Nov 5, 2002 07:03 AM
SMOKEN
Jul 13, 2002 04:01 PM
