MPFI car to TBI
Old Nov 1, 2005 | 08:12 PM
rabrand's Avatar
MPFI car to TBI
Am swapping a 88 305 TBI engine and trans into a 90 3.1 car. I believe the MPFI fuel pump puts out more pressure than I need for the TBI motor,is there a way to regulate this or do I need to swap pumps. I have the complete donor car,but figured I have enough work to do if I can avoid more. TIA.
Old Nov 2, 2005 | 01:45 PM
rabrand's Avatar
Well after searching around,it looks like the TBIs fuel pressure regulator will handle the job. Only one way to find out.
Old Nov 2, 2005 | 05:17 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
This is probly something many people have or will encounter over the years.
Make sure you start another thread or update this one to let us know how it turned out
Old Nov 3, 2005 | 05:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The multi port fuel pump will suffice. TBI systems are low pressure systems and a V6 pump should provide a stable regulated 15 psi at all engine loads with ease.
Old Nov 4, 2005 | 09:27 AM
rabrand's Avatar
Ok,will let you know what happens.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
MENINBLK
Aug 5, 2015 11:58 PM
