Transmission.......
Old Nov 1, 2005 | 10:47 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Transmission.......
I have a v6 firebird its got a 350 on the way. just wondering if i could use the v6 trannyand drive shaft. ive herd of "cutom clutches" and other things but i wouldnt want to put a ton of money into something im un-sure about and destroying my cars transmission. also.. this is a daily driver not too much drag racing going on here.. And would i need V8 gauges?
Old Nov 1, 2005 | 10:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll need a V8 tach, a V6 tach will read high.
Your driveshaft will work, but if your transmission is a V6 700R4, it has a different bolt pattern and won't bolt to a V8 block.
Old Nov 2, 2005 | 12:29 AM
Car: 84 Z28
Engine: carb 305
its a 5 spd manual im pretty sure its called a T5 or something close to that.and my car comes stock without a tach just a shift light that doesnt work. i have a parts car now its a 1983 smokey and the bandit replica rusted and thrashed. would the intstruments work from that car?? its got a carb'd 305 and my v6 is mpfi. thanks alot
Old Nov 2, 2005 | 12:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The gauges will probably be ok. If you change the bellhousing, the T5 will bolt to the V8, but I believe the V6 T5 is built pretty lightly and won't live long. A search should turn up more details.
