191-305 engine swap! Just giving info and hardships happened
Old Nov 5, 2005 | 10:40 PM
Racing_Master's Avatar
Car: 1991 Camaro RS
Engine: 305 TPI V8
Axle/Gears: Stock V6 Rear End
Well I ahve a 1991 camaro RS... used to have a 191. Just recently the engine... pretty much had a heart attack, and stroke, and died. It can start but stalls and has a metal slamming against metal sound in the engine, and all the pushrods are fine. Anyway I had a 305 from a junkyard, bearings were completly shot and piston rods and crankshaft were destroied. So the engine setup (pistons, camshaft, connecting rods, crankshaft, block, oil pan, oil pump, ect) was trashed and I was on the hunt for a new engine setup. Found one for free, along with MAF, and air duct... did I say this was a TPI? The only thing the free engine is missing is the intake, and I have that. After I get the engine a simple swap of oil pump and oil pan, and installation of intake is needed. After that the wiring harness can be installed, then trannie... then I can rip out my old ruined V6. I can sell it maybe to someone, or donate it to my tech school. The V6 had a TH700-R4 in it. I am placing a 5 speed manual with hydrolic clutch on the V8... should be a nice change.
Anyway heared enough of my ranting about my engine? want some pictures? Here are a few, rest available on my website:
CLICK FOR LARGER VIEW
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
armybyrd
Aug 10, 2015 09:23 PM
