TPI or Carb
Old Nov 9, 2005 | 06:32 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
TPI or Carb
i have a carbed 305 in my 92 rs . i was wondering if it would be worth my time to change it to a TPI setup. I found where i can get the whole setup for around $150.00. thats the engine, ecm, and tpi. should i change it. thanks
Old Nov 9, 2005 | 06:33 PM
its out of a 85 trans am with a 305
Old Nov 10, 2005 | 05:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'd want the engine harness, sensors and fuel pump as well.
The '85 TPI set-up wasn't the best, but it was okay as long as you aren't looking to max it out. Whether it would be worth your effort depends upon what you expect out of it.
Old Nov 10, 2005 | 11:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What exactly do you want your car to do? Fuel miser? Speed demon? Bullet-proof daily driver?
Old Nov 12, 2005 | 11:03 AM
im looking for a reliable setup but still be able to pull low 14s- high 13s ETs
Old Nov 12, 2005 | 01:27 PM
five7kid's Avatar
Your current set-up on the TPI engine would be quicker. The TPI would get better economy. Reliability is probably a toss-up.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
