Converted to LT1 intake. what heads are compatiable
Old Nov 9, 2005 | 09:52 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Converted to LT1 intake. need to know what heads are compatiable
I will be using all the stock mounting brackets off of the heads.
Do the dart Iron eagle heads compatiable with these mountings?
thanks
Old Nov 9, 2005 | 10:41 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
need to be 87-up style heads
Old Nov 10, 2005 | 09:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, that means the the center intake manifold bolts are drilled at a different angle.
Old Nov 10, 2005 | 10:23 PM
xpndbl3's Avatar
Car: 1984 Z28
they also call these "centerbolt" heads since the valve covers are bolted in the center of the heads.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
