LS1 suspension questions
Car: 1991 Trans Am
ok i see that Spohn offers both a t56 crossmember and a t56 torque arm/cross member combo. if i were to get just the crossmember, can i upgrade my torque arm later? i would assume so as selling a crossmember that you cant even install a stock torque arm to is rediculous (and if a stock arm fits an aftermarket one will as well). so whats the deal here?
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
the crossmember is just that.. the peice that lets you bolt the tranny in.. the factory torque arm mounts to the tranny like normal
the combo has the torque arm mounting to the cross member not the tranny
can you interchange them.. hell no.. there is no mounting provisions for the torque arm on just the cross member peice.. they are two totally seperate peices
not sure what else u wanna know..
