buick 455 tpi
Old Nov 23, 2005 | 10:47 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
Axle/Gears: 7.5" 4.10
buick 455 tpi
i was wondering if anyone can help me with this process i am trying to fit a tpi system on a big block buick and i am thinking in terms of the distributor because from what i understand the distributor is what give's fuel timing for the injector's and the distributors are both way different as most of you will know so in this case what is your advice on this i also need some advice on a knock sensor how would this work on a buick motor have the intake all set for this process thank you in advance.
Old Nov 24, 2005 | 10:24 PM
LT1guy's Avatar
Car: 1987 Trans Am
The TPI isn't going to fit on a Buick engine. Probably the best solution is to run a modified 4 barrel style intake of your choice drilled for injectors, fab up some fuel rails, and either use a 4 barrel style throttle body or an elbow to adapt a FI style throttle body. Several manufacturers make an elbow to accept the Ford 5.0 style monoblade; Accel makes one that will take the dual blade TPI style. If you are planning to use the factory ECM, you could probably combine parts from a TPI style distributor and the factory unit to come up with a computer controlled distributor. This would be easiest with the large cap style HEI, since the Buicks used a non-cc version of this distributor from 74-76 and they're fairly common. Adding a knock sensor shouldn't be too hard, just drill and tap a hole into a coolant jacket on the side of the block if there isn't already a tapped and plugged hole (not as familiar with the Buick engines to know if they had a block drain plug).
Old Nov 25, 2005 | 01:12 AM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
already have intake setup
i already have the intake setup for this what i am doing is using the buick intake and makeing an adapter for the throttle body for it and welding the injector ports from the tpi intake in the buick intake and thanks for the distributor info on this project also and you think i will run into any other problems on this setup Thank's in advance
ex-x-fire
Jan 12, 2024 01:58 PM
neilb
Oct 4, 2018 12:36 AM
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
