LT1/T56 install: Making the speedo work.
Old Nov 30, 2005 | 11:14 PM
RAGEman's Avatar
Car: 87 Camaro Z28
Im wanting to find the quickest/easiest/cheapest way to convert either my speedo to electronic or my tranny to mechanical. What are most people doing for this swap? How much is it costing you and how is it working out for you?
Old Nov 30, 2005 | 11:19 PM
TexasLT1's Avatar
Car: '92 RS
sorry, can't help you too much. check out www.jagsthatrun.com I've seen it reccommended before, might have something you could use.
Old Dec 1, 2005 | 07:05 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Easiest way, swap the cluster and harness from a '90 model (or '89, can't remember which year Camaro's started the electric speedo) and the underdash wiring.
I did it in my '86 Firebird and it worked out perfect, or you could just swap the cluster and wire the speedo up itself where it screws into the back of the cluster where the printed circuit board is.
Old Dec 1, 2005 | 11:09 AM
RAGEman's Avatar
Car: 87 Camaro Z28
I could be wrong but there has to be something out there that you plug in to the guage cluster that reacts to the sending unit on the tranny. But like I said I could be wrong.
Klortho: The 90-92 speedo fits in with no modifications? How does it look? Out of place? How much did it cost you.
Old Dec 1, 2005 | 11:35 AM
Klortho's Avatar
Car: 1987 GTA
I did a complete cluster swap when I put the LT1 in mine so I would have the gauges. Also went from mechanical speedo to electric and swapped the entire dash harness.
Old Dec 1, 2005 | 12:41 PM
TexasLT1's Avatar
Car: '92 RS
from the website I posted....
https://shell7.tdl.com/~jags/Pages/P...ilHousing.html
thats about the only way of that I know to keep a mechanical speedo. But keep in mind, the PCM still needs a speed input.
Old Dec 1, 2005 | 06:39 PM
RAGEman's Avatar
Car: 87 Camaro Z28
That seems to be the easiest and cheapest way to do it. I think that's what Im going to end up doing. BTW what are the stock gears in my car? 87 IROC-Z LB9 A4 with a 10 bolt.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
