Another LT1 Swap
Old Dec 24, 2005 | 07:45 PM
DF'sCamaro's Avatar
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
Another LT1 Swap
I have been gathering up my parts for my swap and just recently got my complete m6 with clutch and all from a 97 t/a. But here is where I am lost, I have a 92 RS Camaro with a 305TBI in it rite now and my LT1 is from a 92 Corvette(motor being complete bottom end, heads, intake, and accessories bracket, but no accessories). So I have started getting parts for the motor and I know since I'm running my accessories Corvette style I have to Corvette ones but like on the pulleys, harmonic balancer, and power steering pump do I also have to get that off a Corvette? I have already got an ecu and dual fans out of a 94Z28 and a factory wire harness out of a 95Z28. What parts can I get from a Camaro and what parts do I have to get from a Corvette?
Old Dec 26, 2005 | 01:56 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Mines a combination of vette and maro parts. If i had to do it over again i would have used vette pulleys and accessories. I would use all vette parts as long as you have the vette brackets.
Old Dec 26, 2005 | 08:28 PM
DF'sCamaro's Avatar
Car: 1992 RS Black
Axle/Gears: 4.10
Yes I do have the Vette accessory bracket but like a said ^ I do not have any accessories. And there is no pulleys or waterpump on the motor and I have been told that if you use a maro's pump and pulleys on a Vette block it will mess it up, is that true? Im not asking for a list of what parts I need to make it a running motor. Just a compatibility of what parts will work off a camaro or vette. Like if I find a parts car camaro that has all the rest of my accessories I need, can I take off the parts or will it mess up the motor.
Old Dec 26, 2005 | 08:51 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Not sure about wich way the vette parts spin.. I would either go one way or the other. meaning all vette brackets and assesories or all maro. look on ebay for parts. as far as water pumps they are the same. Just get the correct year. you realy should just buy new for reliability anyway. why build a sweet motor and get stranded because of a bad alternator? all you need is a vette alt and ps pump and ac pump/ delete pulley. the rest isnt belt driven.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
