Please I need Advice
Old Jan 20, 2006 | 02:06 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
im currently building a 355 to replace the old 350 in my 1991 Z28. i need to know if my stock speed density will handle the added cubic inchs and the performance camshaft (.495/.503)(.218/.224). will it run at all after i install the engine with out any tuning to the ecm or will i have to burn a chip for it to run. please i need help.
Old Jan 20, 2006 | 02:37 PM
The CID difference is negligible. It's still a 350, for all practical purposes.
Yes it will run; might not run to its full potential, and it might not idle right, but it should at least run. You'll almost certainly have to burn a new chip to get the full benefit of your other efforts.
Old Jan 23, 2006 | 01:44 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Speed density systems are more sensitive to engine changes than mass air flow systems. However, they do provide more control and tunability. My suggestion is to just give it a try and see what happens. Then solve any problems that arise.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
