LT1/LS1 into 3rd gen.
Old Jan 18, 2006 | 08:21 PM
lipe33's Avatar
When swapping an LT1 or LS1 with manual trans into a third generation, does the shifter come up through the factory opening in the console or does it require modification. I would like to swap one of the two into my 89 Camaro, preferably the LS1, but dont want to cut up my interior. What are my options? Any help would be greatly appreciated. Thank you and *** bless
Old Jan 18, 2006 | 08:39 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
you will have to enlarge the hole at the back of the stock opening about 2-3 inches back.
Old Jan 18, 2006 | 11:00 PM
TexasLT1's Avatar
Car: '92 RS
when you pop the shift boot off, you'll see where there is a thicker piece of metal around the shift boot where the screws actually screw into. I cut all the way to the very back edge of that. I've got about an 1/8th" behind the back of the shifter housing.
Old Jan 22, 2006 | 05:28 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
You might also consider using a T-5 5 speed ( later model World class one). This way you wouldn't have to cut your floor at all. I use one in my 87 IROC with a centerforce clutch. It drives great. I do not drag race the car.........but it does go to open track days where it is run as hard as it will go.........Good luck anyway! Pat
Old Jan 22, 2006 | 07:47 PM
Klortho's Avatar
Car: 1987 GTA
Yeah, but that .50:1 6th gear make a whole lot of difference driving on the interstate. Makes a difference between 20-23mpg and 25-27mpg.
Old Jan 23, 2006 | 09:06 PM
hotrodln's Avatar
Engine: Lt1 in IROC
I've actually seen 25 mpg on the highwaywith the lt-1 /T-5 combo......... I guess the 6 speed would do better..........but for me it wouldn't be worth the price of the 6 speed.....I'm thrilled to get the milage I get..........My 84 TA gets a best of 19 on the highway ...........it's got the original electronic quadrajet..........
Old Jan 23, 2006 | 09:08 PM
Klortho's Avatar
Car: 1987 GTA
What gears were in the rear? I'm talking 25-27 with 3.73's and I know of one getting that with 4.10's
Old Jan 24, 2006 | 12:35 AM
ThirdGenLS1's Avatar
Car: 1991 Camaro
i get 29-31 on the freeway with my LS1, but i'm still running 3.42 gears in the rear. My dad with his LT1 get about 25-26 on the freeway with 4.10's.
Justin
Old Jan 24, 2006 | 11:10 AM
hotrodln's Avatar
Engine: Lt1 in IROC
I run 3.27's in the rear, and an aluminum driveshaft. The milage I got was running between 70 to 75 mph on a flat highway.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Dragonsys
Sep 25, 2015 03:51 PM
Nikole
Sep 24, 2015 08:12 PM
