305tbi to383 tpi swap
Im swapping my 1988 305 tbi from my 1988 transam,Im installing a 383 tpi. Im using a wiring harness and computer from a 1986 massairflow tpi.My Question is the iroc had a cable driven speedometer, my 88 has a VSS. HOW do i hook up my speedometer,
Transmission: 4L80E/4L80E
Same way it's hooked up now.
You'd have to check the pin-outs for each harness to be sure, but I believe the VSS uses the same ECM pin, regardless of whether cable or electronic speedo.
Sanjay
Aug 12, 2015 03:41 PM
