87 up block with 416 heads?
Old Feb 23, 2006 | 10:10 AM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
i pulled my 305 today out of my 84 t/a..supposed to be a 2 pc seal L69 engine....
casting number on engine i pulled out of the car
14093627...305...87-91...2...Roller or flat tappet cam, one-piece rear seal
the oddest part is it still has the orginal 416 heads...
i always thought 87 up had centerbolt heads
looks like im off to the store to get a new 84 2pc 153t flywheel
Old Feb 23, 2006 | 10:15 AM
The block will bolt up to either type of heads.
Sounds like somebody swapped the short block at some point, and re-used the original heads. Not alot of mystery in any of that.
Old Feb 23, 2006 | 10:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 87 up block with 416 heads?
Maybe I'm a little slow. What engine are you putting back in?
Old Feb 23, 2006 | 10:49 AM
Car: 84 Trans Am
Re: Re: 87 up block with 416 heads?
1970 2pc rear main seal 350
the flywheel i took from the car doest work, the bolt pattern is off and the hole is too small...the 350 going in had a 168t flexplate on it...
i wasnt aware that the 87 up blocks accepted the older heads...no mystery i guess then
Old Feb 23, 2006 | 11:28 AM
five7kid's Avatar
I think I understand as well now. You expected to be able to use your current 153tooth flexplate on the 1970 engine, only to find out you had a later shortblock.
I'd have to agree with sofa's assessment. Probably happened at a dealer, maybe even under warranty. Put in a new shortblock, reused the original heads.
You had the best of both worlds and didn't even know it. . .
(Did it have a roller cam in it?)
Old Feb 23, 2006 | 11:59 AM
Car: 84 Trans Am
im going to pull the intake off and check
i knew something was up i was running 14.4@96.66 with only a full exhaust, no air cleaner, short throw shifter and the free carb mods
its ok the engine i pulled needed valve stem seals badly and i got the new engine complete from carb to pan(which was recently rebuilt) for next to nothing...
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
