383 MOTORCRATE engines?
Old Mar 14, 2006 | 04:43 PM
bud_light's Avatar
Car: 87 IROC
ok, im about to get this 383 stroker from this place called motorcrate engines. ive called the shop already and sounds decent. im purchasing it off of ebay. does anyone know anything about these guys? good/ bad. here is the combo. let me know what you think. im buying it for 2900.
CHEVY 383/450HP/430FTLBS STROKER ENGINES
THIS ENGINE HAS THE FOLLOWING:
Premium Seasoned 4-Bolt main block.
GM 350/3.750 con rods with NEW HP rod bolts and nuts.
NEW Eagle 383 Steel Crankshaft.
NEW Hyperutectic Flat-Top Pistons 10:1 comp ratio.
NEW Plasma Moly Piston Rings.
NEW Speed Pro Camshaft & Lifters .488/.510 - 234/244 - 117 specs.
NEW Performance Gasket set.
NEW High Volume Oil Pump.
NEW HD Tri-Metal 780 "IROC" Series Rod,Main & Cam Bearings.
NEW Flex-Plate. GM Harmonic Balancer.
NEW HP Gear Drive Timing Set.
NEW Brass Freeze Plugs.
NEW 64CC Aluminum Cylinder Heads, 200CC intake ports with NEW Stainless Steel Swirl Polished 2.02/1.60 valves, Comp Series Springs .530 Lift, Bronze Valve Guides, Hardened Locks & Viton Seals.
NEW Head Bolts.
NEW True Roller Rockers.
MACHINE WORK
Bore and hone block with torque Plate with moly finish.
Deck cylinder block parallel to main line with CBN.
Re-size connecting rods with new bolts & nuts.
Hang and align pistons onto connecting rods.
Line hone main line.
Fully balance engine assembly.
Assemble.
ALL OF OUR ENGINES COME WITH A 5 YEAR / 50,000 MILE WARRANTY!!
Bid today and get screw-in studs
Old Mar 14, 2006 | 07:11 PM
ljnowell's Avatar
Re: 383 MOTORCRATE engines?
NEW Head Bolts.
MACHINE WORK
Assemble.
That whole bid today and get screw in studs is kinda funny. Who in their right mind would build an engine like that and use pressed in studs?
Check the feedback. THen check it again. Then see if you can get some numbers or names and call people.
Old Mar 14, 2006 | 08:59 PM
bud_light's Avatar
Car: 87 IROC
Re: Re: 383 MOTORCRATE engines?
i called, comfirmed the price and shipping. 200$. the feedback is 100% positive and they have been members since jan 04. i guess that says somethin. ill be definatly going through paypal, so ill have statements saying that i paid, just in case something goes wrong. there is insurance on shipping. and i checked that the holley stealth ram will fit on these heads.
Old Mar 18, 2006 | 06:53 PM
BlackRabbitZ28's Avatar
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
They have an ad also in Chevy High Performance Mag. so that says a little more I guess.
Old Jan 27, 2007 | 07:50 AM
corbs69's Avatar
Car: 1992 Camaro RS
Engine: 355 4 bbl.
Transmission: 700-r4
gh
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
