hermonic damper ?
Old Apr 16, 2006 | 07:27 AM
tina23's Avatar
hermonic damper ?
Just like to say hi first.Reason for not posting.If you do a search on this great site youll find what you need. Ok installing older 2piece seal 350 mtr.I read that i need a 82 - 85 flywheel and starter. What hermonic bal. to use one off my 87 350 our the one on the older mtr.Oh ya im not crazy This just to get back to the track While rebuiding the roller mtr.thanks
Old Apr 16, 2006 | 08:55 AM
The 87 crank damper will work fine, if its rubber isn't separated. Use it, and use the stock timing cover that came with it, if you want a timing mark that is useable.
Old Apr 16, 2006 | 01:03 PM
Brettlinetta's Avatar
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
Yes, the harmonic balancer from most any 350 will work, provided that it wasn't a performance engine with a custom crank etc.. then most likely the engine was professionally balanced and the H.B. is different from factory.
_bR3T7
Old Apr 17, 2006 | 07:13 AM
tina23's Avatar
thanks.
Old Apr 17, 2006 | 02:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it was "professionally" balanced, rather than a hack job, the balancer will be untouched and all the weight changes will be on the crank.
MoJoe
Sep 15, 2015 12:50 AM
jimmy_mac
Sep 6, 2002 08:27 AM
Bunker82
Jun 30, 2002 01:36 AM
P J Moran
Apr 17, 2001 09:44 AM
Nitro Don
Mar 17, 2001 10:27 PM
