LT1 swap fuel line question..
Old Apr 23, 2006 | 04:08 PM
jjohnston's Avatar
Car: 91 Camaro RS
My old engine was the 305 TBI. I am puting in the LT1. Do I need new fuel lines? I already got the new fuel pump, didn't know if I needed new lines because of the increase pressure or not.
Old Apr 25, 2006 | 10:24 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
there metal right? i dont see 50psi blowing the lines apart but you want to use the proper fittings not old school hose clamps
Old Apr 25, 2006 | 10:39 PM
Firebat's Avatar
tbi has the same fuel pump and lines as the tpi. The FI V6 pump works also i have heard.
i'm using the old school hose clamps on the rear of the lines by the gas tank but i replaced those hoses with new fuel injection hose. Upfront you'll want to get some lines to go from the intake to the hard fuel lines. Contact lt1intake.com or thirdgen.org member z 2 8 r i c e r,no spaces. Or see what the alternative intake forum guys are doing with their LT1 intake swaps.
Old Apr 27, 2006 | 08:55 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
I cut the TB end off my stock metal lines, flaired them slightly, and joined them with the stock LT1 fuel fittings with high pressure fuel injection hose, then used 2 hose clamps on each end.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
