Timing issue
Old May 2, 2006 | 10:00 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
Timing issue
After swaooing my 305 to a 350 my engine seems to idol high. At almost 900 RPM. (That is after its up to operating temp) Besides that. I set the timimg at 900 during idol and it runs great. After then engine is cool (of course i reconnect the tan wire) and i go to take it for a ride and press the brake and shift it into gear, and wile my foot is still on the brake the engine lowers itself to about 700RPM and the engine struggles to stay running. Does anybody thing that maybe the timing could be fine at a higher rpm but when i put it in gear the timing is far enough off that it can barely run?
Old May 3, 2006 | 09:47 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have carb (computer controlled, I assume), TBI, or TPI?
Old May 3, 2006 | 02:04 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Did you put a bigger cam without adding a stall? My friends truck drops to 500rpms (stock tach is probly off but it is still low) when you put it in gear, so as long as it still runs decent at idle in gear i wouldent wory about it.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
