carb swap for efi ecm?
Old May 16, 2006 | 07:29 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
i've got a cfi z-28 and want to put in a 350...but with a straight carb,,no ecm..but i want to use the elec. in-tank fuel pump w/afpr....do i need to keep the ecm connected for the fuel pump? i know i will need to remove the check engine light bulb....anything else?
Old May 18, 2006 | 12:32 AM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
wdigitog,
I converted my son's '82 CFi to carb. We wanted to keep an ecm and changed his complete harness & computer to a '86 carb harness. I am SOMEWHAT familiar with the crossfire wiring harness. The fuel pump will NOT work without the ECM. You'll have to do some re-wiring to get it to working. You should find several posts where folks have found creative ways to power the pump.
Personally, I prefer using the standard block-mounted pump. It's less expensive than an FPR but will require that you drop the tank and remove the pump. PLEASE DON'T HACK A HOLE TO REMOVE IT IF YOU GO MECHANICAL!
All-in-all you'll probably spend as much time (if not more) installing an FPR and figuring out how to wire the pump than you would to simply remove the pump and install a block mounted. All you'll need is a pump rod as the cam will have a pump lobe.
Depending on what transmission you have installed..... eliminating the ECM will require an aftermarket device to allow the Trany to lock-up in OD. The '83 should have a TH700 which will not lock-up without the ECM.
Sincerely,
Kurt
Old May 18, 2006 | 06:38 AM
wdigitog's Avatar
thanks for the info.....i plan to put a manual trans in...the pump is the only problem......i'll look-see how some of the other guys solve this problem.
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
beachrodder
Aug 25, 2015 08:05 AM
cstrobel65
Aug 15, 2015 10:19 AM
