383 carb swap help
Car: 1989 camaro
383 carb swap help
ok so im just starting this and still collecting parts and im on to ignition now. i don;t want to use the computer for anythign which i shouldn;t if i get a new hei distributor but i was wondering what else i will need ignition wise to get this baby to run right. thanks
Car: 1992 Camaro RS
Axle/Gears: Stock
All you need is the distributor. Plug it in, set the timing, and go.
You may want to look into an ignition box though.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i like the summit $149 ones that have a built in coil and a vacuum can. they have a better ignition module and a higher voltage coil already as well. They also sell a cheaper $89 one that doesn't have those things. Otherwise you could always drop $300+ on a billet MSD dizzy and get the same performance.
