new startup... coolant?
Old Jun 30, 2006 | 10:54 PM
JB22's Avatar
This may sound like a stupid question, I dunno...
I am getting ready to start up the new 350, should I be filling my coolant with 50/50 antifreeze / water, or should I be running straight water in the beginning just due to possible leaks etc... ??
Old Jun 30, 2006 | 11:11 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Are you running a hydraulic roller or flat tappet cam?
Old Jul 1, 2006 | 07:08 AM
JB22's Avatar
roller cam
Old Jul 1, 2006 | 10:20 AM
Lo-tec's Avatar
Your choice. If you're unsure of possible leaks, run water only. After it's been run and no leaks, pull the lower radiator hose to partially drain the engine and fully drain the radiator. Also drain the overflow. Fill with straight coolant. It should take about 2 gallons to fill it up, and the overall ratio should be about 50/50.
Old Jul 1, 2006 | 02:46 PM
JB22's Avatar
Gotcha.
I think I will go with straight water for the startup, just to be sure no leaks.
Old Jul 4, 2006 | 06:26 PM
JB22's Avatar
I went with water, turn out, no major leaks! yay!
forgot to tighten 2 clamps in the back for the heater core... had some drips down the firewall.
Thanks again for the information
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
