old 350 motor with 87 parts
Car: 87 Iroc
Axle/Gears: stock posi
hey guys, i bought a suposidly 350 engine a while ago, and now i have an 87 Iroc 305 tpi. i was told that the 350 i bought is a 70's engine, i was wondering if the tpi stuff needed to convert, off my 87 305, would work on the "older" 350 block.
i only need the stuff to convert the engine to tpi, i am planning on getting the 350 rebuilt at a shop anyway, and bored to a 383, would this be ok?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Second you cant bore a 350 to a 383, you can stroke it, and bore it 30 over which makes a 383 but boring alone is not going to do it.
Also, yes you can use the same TPI stuff on your older motor if you really wanted to.
Just find out the casting numbers or you will be sorry later. trust me ive been burnt with the old "yeah its a 350" bit
Car: 87 Iroc
do the casting numbers just tell you if its a 350? or is it like an ID number?
also, will i have any trouble getting that 350 hooked up in my 87 Iroc? will it hook up to the trans? or will i have to do stuff to get it to work?
Car: '89 IROC-Z Convertible
Car: GTA
Engine: 383 HSR
behind the distributor there will be an upper lip where the bellhousing is bolted into. it is most likely on the right side (passengers) the 5.0/5.7lg stamp is on the drivers side... on the same lip. Find the numbers and I will look it up for you
Driver's side behind head 5.0 or 5.7 (just above my hand). Straight up just to the right of the distributor will be casting number.
Car: 87 Iroc
so all this stuff i got now on my 87 305 tpi will work on the 69-80 350 block even though it was carb? what all would i need to convert it if anything, im planning on gettin the old block rebuilt anyway and bored out to a 383, is this idea any good?
Car: 1983 G20 Chevy
Transmission: 4L60
it says GM
3970010
i hope thats the number.
3970010
Car: GTA
Engine: 383 HSR
well you can stroke it to a 383 if you want,
You will need a 400 crank, 383 pistons, punch your block 30 over and have the block clearanced for the stroke and maybe even the rods clearanced.
It will be pricey but it all depends on what you are looking for in a motor bro. 383 is a good torque motor, perfect for trucks and things of that nature.
Car: 87 Iroc
my main concern is, will everything i need for tpi be able to convert over to my 350? even though the 350 is older, will it still work? like the intake and everything.
Car: GTA
Engine: 383 HSR
You act like you arent very sure if this is even a 350. Look on the back of the motor behind where the dizzy usually is and see if iit says 5.0lg or 5.7lg then attempt to get the casting numbers.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
