dropping the engine in (header clearance questions
Old Jul 4, 2006 | 09:43 AM
kammi10's Avatar
Car: 1989 camaro
i have hooker shorty headers and im aboutt to drop my new engine in but can i bolt the headers up and drop the engine in with them or not?
Old Jul 4, 2006 | 01:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out my garage (house&car-looking icon below member info). That's what my engine looked like just before it was stabbed.
Old Jul 4, 2006 | 10:48 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Yes you can drop it in fine... I use hooker 2055's and drop it in no problem. Took ten minuted to drop it on mounts and pushed the bolts through.
All you have to do is keep an eye on the k-member and the ball flanges. Just a little finese and you will be okay
Old Jul 5, 2006 | 05:09 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I dropped in my 350 without headers. They are not hedmen though. I had to un bolt the right motor mount, and lift the engine slightly to get the right side on. Had to do the same for the left side. Tight fit..
Old Jul 5, 2006 | 10:28 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Makes me wonder how you guys do this and run into so many problems...
i jack up the rear, lower the front and shoe horn everything in accessories and all. You might have to get someone to push on side of the motor to clearance something but it really shouldnt be more than a 10 minute deal
Reddeath210
Oct 6, 2015 08:20 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
