V6 to 350 swap
Car: '88 Bird
Engine: 2.8 V6
Transmission: t-5 5 speed
V6 to 350 swap
i have an 88 pontiac with a v6 and wanna put a 350 in it. i understand ill need a new tranny, rear end, bell housing, and hood. first question is will it fit the motor mounts? 2nd which components will i have to replace(alternator, radiator, water pump, power steering pump.....etc)? 3rd question is, i have the multi port FI but i want a carb, what do i do about the computer? for now those are all my questiones. if you have any parts that i may have forgoten please let me know. thanks.
Transmission: 4L80E/4L80E
https://www.thirdgen.org/forums/engi...swap-read.html
Start by reading that. The EFI-to-carb part is in a tech article accessed from the thirdgen.org homepage.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Why would you need to replace the rear end? V6's usually have a more favorable gear ratio anyways.. just get a posi
