2.8L to a vortec 4.3L
I have a 87 camaro with a tired 2.8L and a friend has offered me a 4.3L vortec v6. I need to know if the 5 speed tranny will bolt on ok. Also I am wondering how hard it will be to change all the wiring for engine electrical.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
For the most part, swapping in a 4.3 is the same as swapping in a V8, because the 4.3 is based on the small block V8.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
So in a nut shell, yes you can use the tranny but not the bellhousing.
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
I am not sure about the vortec motor but i do know that the 4.3 uses the same bellhousing and trans that a v8 305 or 350 uses so skip it and drop in a 350 installing that motor isn't worth it. The 2.8 3.1 and 3.4 uses a different bellhousing all together and to make the fuel injection work will probably suck also. Just my .02
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
A Vortec 4.3 would be a great swap into a 3rd gen.They are lighter than a V8,set back further in the engine bay,and make about the same HP as most of the stock V*s that came in these cars,and would likely get close to 30MPG to boot.Making it all the better,everything to bolt one in not exhists,but is factory GM stuff,just gotta know what to look for.
As far as the trans go's,get a V8 bellhousing.The mounts to bolt it in can be found in 88-98 V6 Chevy pickups.
Don't be discouraged on this swap,if it's a daily driver and not a dragracer,it'll be a good time.
Car: 1983 G20 Chevy
Transmission: 4L60
PS-My pre-vortec Astro 4.3 TBI made 215 RWHP and was a mild build with swirlports on it.
I recently put one in place of the 3.4 that was in my GMC Jimmy. It doesn't have alot more HP in stock form, but the torque increase is incredible.
I bought a rear-ended insurance write-off with under 90,000 miles on it and used all factory parts to pull off the swap. The only non-factory part is the painless harness for the CPI 4.3 that came from Ebay.
monte87cortez
Sep 26, 2015 08:10 PM
