TPI swap into 69 camaro - where to cut firewall?
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Can anyone recommend the best place to cut the firewall in a 69 camaro to pass the TPI harness into the passenger compartment? I'm thinking somewhere above the heater box behind the glove box.
VR,
DZcode
VR,
DZcode
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The stock routing was through a hole on the passenger side of the firewall, right up against the fender. The computer is under the dash, and the wiring basically goes 'around' the firewall.
Transmission: 4L80E/4L80E
Need to keep it 3rd gen related. Using 3rd gen parts doesn't qualify with the topic posted.
Sorry.
Sorry.
