quick transmission question
Old Jul 4, 2006 | 08:39 PM
notredan54's Avatar
3.8L with 5 speed out of a 1998 firebird just wondering if the tranny will bolt up to a 350. I can get it cheap I could be confused but i thought i read it will bolt up with a few different parts just though i'd you guys and see, thanks.
Old Jul 4, 2006 | 10:04 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I'm pretty sure it can be forced to bolt up with the right combination of parts.I'm also pretty sure it would last less time than it takes to bolt it in.
Old Jul 5, 2006 | 07:03 AM
notredan54's Avatar
Isn't the T5 Transmission the same they use with the the mustangs and gm trucks
Old Jul 5, 2006 | 11:55 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The bellhousing won't work. I'm not completely clear on what exactly that T5 is.
Old Jul 5, 2006 | 12:20 PM
notredan54's Avatar
hey thanks for the answers to my question so it wont bolt up and if it could it wouldn't be strong enough. I'm still learning here thanks alot.
Old Jul 5, 2006 | 02:29 PM
five7kid's Avatar
Try the Transmission and Drivetrain forum, if you haven't already. I don't spend a lot of time there, but believe I've seen it discussed. The later V6 T5's are stronger than the 3rd gen T5's (after all, the 4th gen V6's put out as much power than 3rd gen V8's, right?), but that's all I can remember off the top of my head.
Old Jul 5, 2006 | 02:41 PM
notredan54's Avatar
Thank you Five7Kid
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
