flywheel help
Old Jul 5, 2006 | 07:14 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
flywheel help
ok im swapping in a 400 into my iroc, are all 400s externally balanced? if now how do i distinguish?
i have a early model flywheel that im trying to use, just want to make sure that all i need is the balancer plate to go behind it.
Old Jul 5, 2006 | 08:37 AM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
An engine building book I have isn't distinct but seems to infer the 400 is externally balanced unlike the 350
Old Jul 5, 2006 | 09:02 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
were all factory engines externally balanced?
im pretty sure ill need the balancer plate for the back of the flywheel, just wanting to make sure everythings gonna work together
Old Jul 5, 2006 | 11:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
All factory 400's were externally balanced using weights on the damper and flexplate/flywheel. You can use the weight plate with a neutrally-balanced flexplate, but you still have to use a weighted damper.
Or, you can have the crank internally balanced for many $'s. I believe you can also get an aftermarket internally balanced crank, although they tend to be one-piece rear main seal cranks.
Old Jul 5, 2006 | 12:47 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
ok im running a stick and i have a 2pc rear main flywheel from a 84 z.
will that work? they are neutrally balanced right?
Old Jul 5, 2006 | 02:00 PM
five7kid's Avatar
An '84 flywheel will be neutrally-balanced. What I'm not clear about is whether that balancing weight tab thing works with a flywheel. I've only heard of it being for flexplates.
Old Jul 5, 2006 | 02:06 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
does anyone know if it will work, im sure someone on here has run a t5 with a 406?
Old Jul 5, 2006 | 02:34 PM
five7kid's Avatar
If you can believe Summit Racing - High Performance Car and Truck Parts | 800-230-3030 , p/n SES-3-60-11-026:
"Counter Balance Plate, Steel, Use with Neutral Balance Flexplate/Flywheel, Chevy Small Block, 383 Stroker,Each"
Old Jul 6, 2006 | 07:55 AM
chesterfield's Avatar
Car: Pontiac
$36.95 From Summit
$12.95 here:
Balancing Plate S/B & 454 B/B Chevy
and here:
Midwest Motorsports : Balance Plate - Use 350 Flywheel on 383/400 (Engine & Accessories - Accessories)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
