1.6 roller rocker arm ??
Old Jul 16, 2006 | 12:11 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
I have an 89 camaro RS and i swapped out the 305 for a 350 with a very mild cam. Like one step above factory. I put 1.5 roller tip rocker arms on and it runs fine. I am wondering if i can put 1.6 Full Roller rockers on without any problems such as changing push rods or clearance issues? O yea, I have the factory centerbolt heads on the 350. Help???
Old Jul 16, 2006 | 01:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You should be able to use 1.6 rockers without running into problems, unless the lift becomes too much and you have valve guide clearance problems.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
