can i remove efi wires under hood
Old Jul 16, 2006 | 08:21 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
well the previous owner of my car had swapped from efi to a carb so their is a bunch of wires and crap just kinda floating around in the engine bay so i was wonder if it would mess anything up if i started snipping all the wires that arent connected somewhere?
Old Jul 17, 2006 | 01:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a connector at the passenger side kick panel that contains all of those wires. Remove the plastic fender liner and you can get right to it. Unplug that, and remove all of the wires in one piece. Better than cutting,
Old Jul 17, 2006 | 05:03 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
great just wanted to know if it would make the car act funny if i did but it sounds like youve done it before so if you hadnt had an problems then it sounds good to me
Old Jul 18, 2006 | 10:55 AM
five7kid's Avatar
In the interest of full disclosure, I haven't done it myself, but I have pulled that harness and the "essentials" harness from my V6 can and the V8 donor car, and there are plenty of people on the Board who have done it with their non-computerized conversion to believe them.
Old Aug 1, 2006 | 08:01 AM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
just do yourself a favor and ditch that old POS carb and go back to F.I.
Old Aug 1, 2006 | 09:20 AM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
no way would i ever go back to carb and thats not even the question at hand. I never asked if i should go back to F.I.
Old Aug 1, 2006 | 09:36 AM
If you take the wiring out all in one piece without hacking it or otherwise sodomizing it, you might just be able to make some money off of it. People whose wiring has already suffered a similar fate, but who want to restore their car to its correct function, can use an un-hacked harness.
Why it is that people see wires and immediately the first thing they think of is cutting them, is beyond me. Few other things that are that intricate and valuable seem to inspire the urge to just turn them into garbage. Some psychologist could do the world a favor by researching why wiring has that effect on so many people.
As five7 said, it's REAL EASY to take it all out, all in one piece, INTACT and unviolated. Probably easier than hacking it to bits. And that way, it's still worth something to someone after you're through.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
beachrodder
Aug 25, 2015 08:05 AM
3rdgenparts
Aug 8, 2015 07:09 PM
