Optimum timing on a ZZ4 crate
Old Jul 23, 2006 | 11:55 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
What is the correct baseline timing?
New ZZ4 crate, TPI, Edelbrock Hi Flow Runners, TES headers, prom by Fastchips.
Thanks!
Old Jul 24, 2006 | 12:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The correct initial timing is set by whoever did the chip. It *should* be the same as a regular TPI, 6 degrees. Max timing at wide open throttle should be around 32-36 degrees, depending on what your engine responds the best.
Old Jul 24, 2006 | 02:22 AM
Engine: ZZ4 TPI
Thanks Kevin, now here's what may be a dumb question but,...
The engine idles OK right now and is pretty much driveable, how much tolerance or leeway can (if any) can be compensated for by the ecm?
As I understand it the ecm pretty much controls timing.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
ezobens
Aug 19, 2015 10:29 PM
