few quick and easy questions
Old Aug 3, 2006 | 06:04 PM
formulafastfoot's Avatar
Car: i have a 2003 ford zx2 and a 1989 f
Engine: 350 tuned port, 4 banger on the Z
Transmission: 700r4 poop loser
Axle/Gears: 3.23 standard ...one tire fire
ok im pulling my motor and trans and dropping it in the same car just a year younger .. fire bird to firebird ... so is it easier to pull the motor and trans together or is it easyer to unbolt the motor and pull it and then pull the trans and do the reverse for install ? and dose any one know how to wireup a stock alternator in a carbed motor ?
Old Aug 3, 2006 | 06:10 PM
j dezzy's Avatar
Car: 87 TA
I've found it easiest to pull the motor and trans together. have a couple friends around to help. same when dropping it in. maybe if I had a lift I might think different...but I don't...
Old Aug 3, 2006 | 06:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's a matter of preference, and what tools you have available.
Old Aug 3, 2006 | 08:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
together usually yes
no need to separate, you can get it to go in together jut fine as long as you can get the drivetrain combo up high enough to get the tilt you need to get the trans over the x member and down through there
gotta be a pretty steep angle
good luck
Old Aug 5, 2006 | 12:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Together works if you have something like a shop crane that lifts high enough. If you're using something more like a chain block hanging from the rafters, then separately works easier.
Jorlain
Aug 24, 2022 05:11 PM
Dkelz313
Apr 7, 2016 10:38 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
