Tempermental Starting
Old Aug 8, 2006 | 04:07 PM
pontiac86ta's Avatar
Car: 86 Trans Am
Engine: 305 4bbl V8
I replaced the starter a couple of years ago. Recently, the car has had a tempermental start. It mainly does it when the car gets hot for a lil while (like a 20 min or so drive). It will restart right after I turn off the key, but if it sits there a couple of minutes, it won't fire. Car doesn't get too hot, usually about 230 or so during these hot days of summer
All the gauges work, headlights work, radio works, alarm, etc, etc...except there is no fire. So, if you give the car about 20 mins or so to cool down some, it will start just fine. (even on the first fire). And when its running...its purrs like a new kitten...no miss or anything.
Any ideas?
Old Aug 8, 2006 | 07:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
You need more voltage to the starter solenoid, or a solenoid that doesn't need as much voltage. I've recently suffered through the same thing, too much voltage drop across the ignition switch and neutral safety switch.
I haven't had a lick of trouble after installing a remote starter solenoid. If you need details, either , or ask.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
