Part Numbers
Car: 90 Iroc
Engine: L98 TPI
Axle/Gears: 3.23s
Part Numbers
Can anyone give me the part numbers for the knock sensor and esc module needed for the 305 to 350 tbi swap? If not, can someone just point me in the right direction of where to find them. I'm not having any luck so far
thanks for all your help! -Kyle
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Don't know if this will help....
All I did to get the proper part number for the "Knock Sensor" was go to AutoZone's website and lookup any Camaro with 350 & Carb. That's probably the best place ($$$) to get one anyway. As far as the module is concerned, one of the other guys probably has more detailed and accurate information but I changed ONLY the "Knock Sensor" and the car runs perfectly!!!
In your case...... I just looked up a 1990 Iroc w/ 350 F.I. & on A.Zone's Web-Site. They list a "WELLS SU169" for that vehicle. It's $39.99.
Kurt
Transmission: 4L80E/4L80E
1992 Trans Am
May 10, 2023 07:19 PM
IrocZ'85
Aug 17, 2015 06:24 PM
