Put zz4 crate motor in 2.8 Firebird
Old Sep 4, 2006 | 01:18 AM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
How hard will it be to convert a 2.8 to zz4 crate motor. I have read the stinky already. Has anyone done it
Old Sep 4, 2006 | 02:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're doing a V6 to V8 swap. The V8 just happens to be a ZZ4. No biggie. In fact, the factory put out a kit with a ZZ4 in it for 3rd gens (but already with V8), so it's not that big a thing.
Mine is basically a ZZ4 clone.
Old Sep 5, 2006 | 09:58 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
It's easy if you go with a carb. You'll want to reprogram the ECU so it doesnt throw SES lights all the time.
You'll also need a bracket to adapt your automatic to the carb. I recommend the setup at bowtieoverdrives.com
I swapped the ZZ4 crate into my original V8 TBI car. We installed the engine and were breaking it in within one weekend. The main things you'll have to worry about are the accessories brackets and the engine mounts. There is also some rewiring that needs to be done.
Old Sep 5, 2006 | 11:34 AM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
The car is manual.
Old Sep 5, 2006 | 12:23 PM
five7kid's Avatar
What induction do you plan on running?
Plan on changing the clutch, bellhousing, and transmission.
Old Sep 5, 2006 | 12:48 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
yes i am going with a more aggressive clutch and i am getting a Chevy Bellhousing or i might get this part from jegs to make pontaic trans fit on chevy engine.
Old Sep 5, 2006 | 02:18 PM
five7kid's Avatar
Carb? TPI?
Old Sep 5, 2006 | 03:39 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
carb
Old Sep 17, 2006 | 01:07 AM
net_coma's Avatar
Easy stuff, you need 12V and a brain. Have either? No wires to a carb..duh.
Old Sep 19, 2006 | 03:24 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i think the adapter is the BOP v-8 trans boltpattern to chevy v-8. thats not what you need. you have a v-6 trans and you need a v-8 trans. i dont have a manual so i dont know if you can just swap bellhousings. im guessing it wont last long anyway.
Old Sep 20, 2006 | 10:53 AM
mdricken's Avatar
Car: 92 Camaro
Dont forget the electric choke wire. And don't tie the choke wire to the distributor circuit because it can drag down the spark output.
Old Sep 26, 2006 | 07:56 PM
xx_ED_xx's Avatar
Car: 04 Silverado
Engine: 8.1
Transmission: t56
the v6 manual trans has a longer input shaft then the v8's
so just changing the bellhousing wont work
Old Sep 27, 2006 | 06:45 PM
five7kid's Avatar
I've heard the manual V6 trannies have a smaller/fewer spline input shaft than the V8 versions, but never that it was a different length. Several members have used the V6 manual tranny with a V8 bellhousing on a V8, but nobody would argue it is ideal.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
