305 TBI TO CARBED 350
Old Sep 5, 2006 | 03:10 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
has anyone done this before? i know i will need a hei distributor but what else will i need? it is a gm goodwrench crate engine. what size of carb would be the best? any advise would help. thanks
Old Sep 5, 2006 | 03:24 PM
j dezzy's Avatar
Car: 87 TA
a GM crate motor will bolt right up. I would assume you'd need a new computer, unless you decide to do away with that as well. definatly an HEI distributor. the size carb is all up to you. the average 350 takes about a 500-600 cfm...
Old Sep 27, 2006 | 12:44 AM
estone06's Avatar
Car: 1991 Camaro RS
Engine: 350 stroker .40 over 11:1 comp
(Edited by Moderator)
---anyway, just to reaffirm to myself, the 305 tbi swapped to a 350 carb would not need a fuel regulator right? i know the 350 carb is going to be lookign for 5-7 psi but the pump currently inside the gas tank would be pumping that anyway right?
Old Sep 27, 2006 | 06:23 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
He will need a regulator if he is using the tbi pump, or tpi pump. Either way, Mallory makes a return style regulator.
Zach
Old Oct 1, 2006 | 02:01 AM
jeff350's Avatar
will need a regulator for sure with TBI pump.I have a mallory 4309 and it works good.
Jeff.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
